PWB version 3.05.0 CEF/IE Released
Locked
PWB version 3.05.0 CEF/IE (12-02-2016) has been released and includes the following changes. See the "ReadMe.txt" file for complete change history.
Version 3.05.0 12-02-2016
Fixed/Changed:
Changed to CEF 2883 Chrome 55
Changed to allow CEF to determine new windows.
Changed from INI version 3.00 to 3.05.
Changed to include Google Geolocation functionality (CEF).
Changed to include text on Kioskbar buttons.
Fixed Alt-Home to go to home page.
Fixed Default Zoom Level in CEF.
Fixed [Browser]SetFocusTab=0.
Fixed closing of windows via JavaScript under certain circumstances.
Fixed [Overrides]ShowAddressBar not showing address bar.
Fixed support for [Browser]DisableNewWindow and [Browser]DisableNewTab independently.
Fixed custom protocols in CEF version.
Changed CEF to support Print Preview.
Added:
[Browser]EnableLargeTabs=False Enables larger tabs.
[Browser]TabWidth=200 Sets width of tabs.
[Browser]DisableShowLastTab=True Disables showing last tab when only one tab is open.
[Files]KioskbarFolder= Shellbar embedded in Kioskbar. See Shellbar.
[Security]FilterIgnoreEmpty=True Filter ignores empty URLs.
[Java]EnableExternalJava=False Enable Dynamic External Java Commands. (IE)
[Java]JavaExit= Dynamic External Java Command Exit PWB. (IE)
[Java]JavaActivity= Dynamic External Java Command Set Activity Time. (IE)
[Java]JavaRegister= Dynamic External Java Command Set Registration Code. (IE)
[Java]JavaHideToolbar= Dynamic External Java Command Hide Toolbar. (IE)
[Java]JavaExecute= Dynamic External Java Command Execute Application. (IE)
[Java]JavaReadINIFile= Dynamic External Java Command Re-read INI file. (IE)
[Java]JavaPrint= Dynamic External Java Command Print Web Page. (IE)
[Java]JavaHideAddressBar= Dynamic External Java Command Hide Address Bar. (IE)
[Java]JavaOverrides= Dynamic External Java Command Show Overrides Dialog. (IE)
[Java]JavaStartApp= Dynamic External Java Command Start Application in new Process. (IE)
[Java]JavaSetActivity= Dynamic External Java Command Set Activity Time. (IE)
[Java]JavaGetActivity= Dynamic External Java Command Get Activity Time. (IE)
[KioskButtons]ZoomIncrease=True Shows Zoom increase button on Kioskbar.
[KioskButtons]ZoomNormal=True Shows Zoom normal button on Kioskbar.
[KioskButtons]ZoomDecrease=True Shows Zoom decrease button on Kioskbar.
Removed:
Locked
