Target Switch in Shortcut?
BrandonLIT
Post by BrandonLIT »
Hello,
I wasn't able to find any info about my question so here goes!
I work for Wake County Library system and currently we are using PWB centralized on a server to browse our catalog of books. We'd like to be able to keep the centralized server setup and also be able to pull location specific info from the catalog via URL.
Example, www.wakegov.com/libraries/?loc=NER (not a valid URL).
I know with most browsers you can set a web shortcut on the desktop to launch your browser and open a specific URL.
Does PWB support this, if so, how do I go about implementing it?
Currently our .ini is set to up a generic url that points to our catalog. If it supports this will I also need to remove this url?
Brandon
Re: Target Switch in Shortcut?
Set PWB are the Default browser from the user logged onto windows and create an Internet shortcut as usual.
Alternatively you can create a shortcut to PWB with the URL as the argument.
