Running PWB 3 CEF, with the supplied INI file, and the Google logout (i.e. the circle in the upper right corner with letter or photo) is invisible... until you click on that spot on the screen.
Then, you can see the bottom edge of the circle only, and the dialog box (with 'logout') appears (and it looks normal).
Please see attached image to help illustrate what is occurring.
Is there a change of INI (or other procedure), so that the circle will appear?
Thank you.
Can't see "circle" to logout of Google
- teamsoftwaresupport_GoogleDrive.png (110.03 KiB) Viewed 14524 times
Re: Can't see "circle" to logout of Google
If you use an unedited INI file does the account link on Google work?
What version of PWB v3 CEF are you using?
With the current version 3.05.0 CEF the link to work.
I am using version 3.0.5.0 Dec 16, 2016
and the supplied/generic INI file
on Windows 7
Thank you for the screenshot.
I will keep experimenting.
on Windows 7
- temp.png (13.8 KiB) Viewed 14503 times
Try disabling the URL filters.
CheckURLAccess=False
