Not able to auto launch DOCX files using the Execute Filter
Rockhard
Post by Rockhard »
We are unable to launch any DOCX files, when we have the Execute Filter enabled.
We are able to execute the DOC files, but not the DOCX files. Please advise how we can have the DOCX files auto execute.
In the Excecute file we have the following defined:
!application/msword
!application/x-msword
!application/vnd.openxmlformats-officedocument.wordprocessingml.document
!application/vnd.openxmlformats-officedocument.wordprocessingml.template
!application/vnd.ms-word.document.macroEnabled.12
!application/vnd.ms-word.template.macroEnabled.12
Re: Not able to auto launch DOCX files using the Execute Filter
Do you have an example of a link that uses the DOCX format?
Rockhard
Post by Rockhard »
the link is only on our Intranet. But it could be any DOCX file. Even in an email
It seems to work as expected using your Execute file and the following link as an example:
https://www.teamsoftwaresolutions.com/docx/test.html
From the History File:
TSSWKS99 1/18/2018 11:16:08 AM <a!> application/vnd.openxmlformats-officedocument.wordprocessingml.document
Did you enable the Execute filter?
CheckExecuteAccess=True
Rockhard
Post by Rockhard »
We seem to be using a Joombla back end that has these files stored in a remository and the user clicks on download from there.
That is where the issue seems to be with Execute for DOCX files. The DOC files downloaded from the remository seem to open file through the PWB using the Execute filter.
Without being able to test it directly it will not be possible to give you the information for the execute filter. However you should be able to use the history file to determine what to put into the execute filter file.
WriteHistoryFile=True
TrackURL=True
LogAccess=True
Rockhard
Post by Rockhard »
Got it working.
It was
!application/force-download
