Disabling Zoom/Pinchzoom
MasseyRob
Post by MasseyRob »
Hi all
We are setting up a touch screen with a webpage that is going to show our new books list that will be out in a public space running the latest version of PWB CEF. One thing we are struggling to prevent happening though is pinchzoom. Is there a way in the ini file to prevent zoom/pinchzoom? I have searched zoom and set everything to false that we thought might allow zooming, but it still allows pinchzoom.
As always, all suggestions welcomed and appreciated :)
Cheers
Rob
Massey University Library
Re: Disabling Zoom/Pinchzoom
If you are using PWB CEF, try adding --disable-pinch to the command line that starts PWB. This is the Chrome command line to disable pinch-zoom.
https://peter.sh/experiments/chromium-c ... -switches/
MasseyRob
Post by MasseyRob »
Scott wrote:If you are using PWB CEF, try adding --disable-pinch to the command line that starts PWB. This is the Chrome command line to disable pinch-zoom.
Perfect.. many thanks, Scott
Cheers
Rob
Kernan
Post by Kernan »
MasseyRob wrote: Thu Feb 07, 2019 1:53 pm Hi all
We are setting up lightweight wheelchairs and a touch screen with a webpage that is going to show our new books list that will be out in a public space running the latest version of PWB CEF. One thing we are struggling to prevent happening though is pinchzoom. Is there a way in the ini file to prevent zoom/pinchzoom? I have searched zoom and set everything to false that we thought might allow zooming, but it still allows pinchzoom.
Cheers
Rob
Does PWB share a lot of the same commands like this with Chrome in general?
PWB CEF which uses the Chrome HTML rendering engine uses almost all the Chrome command line switches.
