PWB version 3.05.5 CEF/IE Released
Locked
PWB version 3.05.5 CEF/IE (04-30-2019) has been released and includes the following changes. See the "ReadMe.txt" file for complete change history.
Version 3.05.5 04-30-2019
Fixed/Changed:
Changed to CEF 3683 Chrome 73
Changed to include libpwb.dll keyboard hook for inactivity timer
Fixed CEF Home page navigating multi frames starting timer
Fixed CEF issue when a page opens a new page, prints and closes the page
Fixed Inactivity timers to make them more consistant
Fixed Theater mode
Removed:
Locked
