Disable Compatibility Mode PWB IE
bkasekamp
Post by bkasekamp »
Is there a setting in the PWB3 IE ini to disable compatibility mode? I see some posts mentioning IEBrowserEmulation but I'm not sure if that's it or not. I specifically need "Display intranet sites in Compatibility View" disabled.
Re: Disable Compatibility Mode PWB IE
The Internet Explorer Web Browser Control PWB IE uses does not have a "compatibility mode". By default uses the version of Internet Explorer installed on the computer.
You can set the Internet Explorer Browser Emulation in PWB with the [Browser]IEBrowserEmulation= setting. For example setting [Browser]IEBrowserEmulation=9000 PWB with switch the Internet Explorer Web Browser Control into IE 9.0 emulation.
Here is more information about the Internet Explorer Browser Emulation:
https://blogs.msdn.microsoft.com/patric ... atibility/
It is highly recommended to use PWB CEF which uses the Chrome HTML Rendering Engine.
