PWB version 3.05.6 CEF/IE Released
Locked
PWB version 3.05.6 CEF/IE (08-16-2019) has been released and includes the following changes. See the "ReadMe.txt" file for complete change history.
Version 3.05.6 08-16-2019
Fixed/Changed:
Changed to CEF 3770 Chrome 75
Fixed Alert dialog showing behind window when [Browser]AlwaysOnTop=True
Changed Inactivity Timer to not reset on page load with [Inactivity]ResetOnNavigation=False
Fixed error after clicking home immediately after print when forcing print preview and home buttons close.
Fixed Ctrl+Mouse Wheel zooming.
Fixed PDF file not always showing in frame.
Removed:
Locked
