PWB version 3.05.7 CEF/IE Released
Locked
PWB version 3.05.7 CEF/IE (11-16-2019) has been released and includes the following changes. See the "ReadMe.txt" file for complete change history.
Version 3.05.7 12-16-2019
Fixed/Changed:
Changed to CEF 3904 Chrome 78
Fixed background erase on minimize
[Printer]ForcePrintPreview=True Enable Chrome Printing Preview
Removed:
Locked
