Inactivity Dialog Box Question
pmoorman
Post by pmoorman »
I'm testing PWB 2.05 for our OPAC terminals, I have the INI configured as I would like on my machine, but when I tested it in the computer it will be used used in, everything looks the same, except the inactivity dialog box does not appear when I should. The INI files are identical. Any ideas what might be causing the dialog box not to appear in the second computer? Thanks.
If you are using Trend Micro OfficeScan, we are currently checking into why OfficeScan seems to be resetting the PWB inactivity timer.
