I was able to add shortcuts to aimexpress and webmessenger in the shellbar (i figure if patrons have this option first, they won't be tempted to install aim or msn messenger).
webmessenger works fine (webmessenger.msn.com) and aimexpress will open the login page (aimexpress.aim.com), but after I type in my username and password for aim express and click login, it starts to open the buddy list and quickly closes it.
It works fine in updated IE 6.
I'm using PWB ver. 2.05 with +all in the url.txt.
Aimexpress and webmessenger
Rudy Ramos
Jerome Library ITS
Bowling Green State University
Jerome Library ITS
- Philip - Long Beach NY
- Benefactor
Do you have pwb set to close any pop up windows? That's what I'm thinking. If you have the pop up button displayed in the toolbar you can turn it off and see if it allows the screen window to stay. Otherwise, I'm sure Scott has other suggestions.
Phil
Long Beach, NY
Phil
Long Beach, NY
-- Steve Gibson
-- Steve Gibson
no popups are blocked or set to be blocked
and I've set limit on second window to 500
Rudy Ramos
Jerome Library ITS
Jerome Library ITS
Send a copy of your INI to Support@TeamSoftwareSolutions.com. Using a stock INI file with PWB v2.05 http://aimexpress.aim.com/ works correctly.
