PWB version 3.05.9 CEF Released
Locked
PWB version 3.05.9 CEF (11-04-2020) has been released and includes the following changes. See the "ReadMe.txt" file for complete change history.
Version 3.05.9 11-04-2020
Fixed/Changed:
Changed to CEF 4240 Chrome 86
Fixed [Browser]DisableExit=True in CEF version
Fixed HDPI for Shellbar in CEF
Fixed libpwb.dll loading issues on specific devices
Fixed PWBIdler3 [Browser]StartTimersOnMouseKeyboard=True starting timers
Removed:
Locked
