2.06 Printing
2.06 Printing
Just installed 2.06 beta and noticed one small issue. Customers can use the 'print' option from the context menu and PWB doesn't load the print dialog or force a print preview.
Of course, I do have these options enabled and they work when printing from the menu or toolbar.
Greg
Unfortunately the context menu is controled by Internet Explorer. PWB builds it using the IE information and has no direct control over it. The print item on the context menu will behave exactly as the context menu print item in IE.
If you are using force print preview in PWB you may want to disable the context menu print item.
GregP
Post by GregP »
OK, thanks
Greg
