PWB version 3.05.16 Released
Locked
Version 3.05.16 06-26-2023
Fixed/Changed:
Updated to Chrome 114
Fixed overrides second try failure
Fixed issue with external PDF viewer with spaces in file name
Changed to include BLOB in Only Access HTTP and Only Access Internet
[Browser]UseRAMCache=False Uses RAM for cahce instead of hard drive
[Browser]DisablePWBUserAgent=False Disables adding PWB to the User Agen String
[Printer]CheckPrinterAccess Enable Print URL filter
[Printer]CheckPrinterFile Filter file for Print filter. +/-URL to allow printing. Similar to the URL filter
[Printer]CheckPrinterMessage HTML formatted message shown when printing is blocked.
[Security]DisableFileOpen=False Disables JavaScript open file dialog
[Files]DisableFileDialogFile= Used with [Security]DisableFileDialog, when file is listed the dialog will show when File Dialog is disabled.
Removed:
Locked
