PWB version 3.05.17 Released
Locked
Version 3.05.17 05-06-2024
Fixed/Changed:
Updated to Chrome 124
Changed to include Print Preview in Only Access HTTP and Only Access Internet
[Browser]UseRAMCache=False Uses RAM for cahce instead of hard drive
[Browser]DisablePWBUserAgent=False Disables adding PWB to the User Agen String
[Printer]CheckPrinterAccess Enable Print URL filter
[Printer]CheckPrinterFile Filter file for Print filter. +/-URL to allow printing. Similar to the URL filter
[Printer]CheckPrinterMessage HTML formatted message shown when printing is blocked.
[Security]DisableFileOpen=False Disables JavaScript open file dialog
[Files]DisableFileDialogFile= Used with [Security]DisableFileDialog, when file is listed the dialog will show when File Dialog is disabled.
Removed:
Locked
