Keeping users on PWB
danm
Post by danm »
Our genealogy computer has a home page with genealogy links. I want to limit patrons to home page and links. Recently, we had patrons get on Youtube with this machines.
I thought of the following commands to confirm/activate:
    DisableContextMenu=True, Disables context (right click) menu.
      AddressBarReadOnly=True, Makes address bar read only.
        DisableNewWindow=True, Disable new windows.
        Any other recommended settings? I held back on disabling tabs in case genealogy links open in new tabs.
        Dan Moenning
        Library Technology Specialist
        Keene Memorial Library
        Dan Moenning
        1030 N Broad St
        Fremont, NE 68025
        Ph: 402-727-2694
        www.fremontne.gov/library
        danm
        Re: Keeping users on PWB
        Post by danm »
        UPDATE: 8/19/2024 at 2:45 PM.
        I tested out navigating away from the home page and genealogy links. I was successful doing the following:
        • I opened a genealogy link.
        • In the new window, I right-clicked a random link
        • From the right-click menu, I selected "Save Target As."
        • I saved the link as HTML on the Desktop
        • From the Desktop, I opened the HTML icon.
        • The page that opened was a regular webpage. I was able to surf the Internet.
        Is there a setting to prevent this scenario? Any insight is appreciated.
        Dan
        Dan Moenning
        1030 N Broad St
        Fremont, NE 68025
        Ph: 402-727-2694
        If you have the following set in your INI file it should not be possible to right click a link and get the context menu.
        If you need some of the context menu, but not the Save As set the following.
        UseCustomContextMenu=True
        [ContextMenu]
        SaveTarget=False
        To keep the patron on a web site you can use the PWB URL filters.
        viewtopic.php?t=13
        If you still have problems please send an email to support with your INI file attached.
        In the soon to be released PWB v3.2 Edge you can set the following to prevent the Open and Save dialogs.
        DisableFileOpen=True
        DisableFileSave=True
