Keeping users on PWB
Posted: Mon Aug 19, 2024 10:56 am
by danm
Our genealogy computer has a home page with genealogy links. I want to limit patrons to home page and links. Recently, we had patrons get on Youtube with this machines.
I thought of the following commands to confirm/activate:
    DisableContextMenu=True, Disables context (right click) menu.
      AddressBarReadOnly=True, Makes address bar read only.
        DisableNewWindow=True, Disable new windows.
        Any other recommended settings? I held back on disabling tabs in case genealogy links open in new tabs.
        Dan Moenning
        Library Technology Specialist
        Keene Memorial Library
        Re: Keeping users on PWB
        Posted: Mon Aug 19, 2024 1:51 pm
        by danm
        UPDATE: 8/19/2024 at 2:45 PM.
        I tested out navigating away from the home page and genealogy links. I was successful doing the following:
        • I opened a genealogy link.
        • In the new window, I right-clicked a random link
        • From the right-click menu, I selected "Save Target As."
        • I saved the link as HTML on the Desktop
        • From the Desktop, I opened the HTML icon.
        • The page that opened was a regular webpage. I was able to surf the Internet.
        Is there a setting to prevent this scenario? Any insight is appreciated.
        Dan
        Posted: Mon Aug 19, 2024 10:06 pm
        If you have the following set in your INI file it should not be possible to right click a link and get the context menu.
        If you need some of the context menu, but not the Save As set the following.
        UseCustomContextMenu=True
        [ContextMenu]
        SaveTarget=False
        To keep the patron on a web site you can use the PWB URL filters.
        viewtopic.php?t=13
        If you still have problems please send an email to support with your INI file attached.
        Posted: Mon Aug 19, 2024 10:07 pm
        In the soon to be released PWB v3.2 Edge you can set the following to prevent the Open and Save dialogs.
        DisableFileOpen=True
        DisableFileSave=True
