PWB v3.20.08 Edge Rendering Engine
foclan
Post by foclan »
Hello
In the PWB.INI file, I have the definition 'ShowPrintingDialog=False'.
When I press the print button, it prints directly to the default printer (normal).
But with ctrl+p when the focus is on the displayed page, the printer dialog appears (not normal).
Can you help me?
Thierry
Re: PWB v3.20.08 Edge Rendering Engine
PWB v3.20.09 Release Candidate 2 now available has the following fixes.
Version 3.20.09 01-22-2026
Fixed/Changed:
Fixed Download window showing with Ctrl-J when [Security]DisableFileDownload=True
Fixed Print dialog showing when [Printer]ShowPrintingDialog=False and Ctrl-P is pressed when WebView has focus.
Added:
[CloseWindows] Section. Each key in the section should contain a window title to be closed when PWB loses focus.
Removed:
