PWB fails to recognize registration
I have a PC where PWB suddenly has become unregistered. I use the same INI file on 4 computers and the other 3 have no problem. I have double-checked the registration information and everything looks good. Any suggestions of what might be awry?
Make sure PWB is getting the right INI file. The only difference between the registered and unregistered version is the registration information found in the INI file.
If you are using alternate INI files check to see if all the INI files have the registration information in the INI.
If you are using a command line to specify the INI file and you have PWB set as the default browser, make sure PWB is getting the INI on the command line through the file association.
Fixed this - it was a system clock issue where the clock had been set ahead to 2004. The browser thought its registration had expired.
