Disabling alt-ctrl-del
wgragg
Post by wgragg »
I need to disable alt-ctrl-del for PWB, but only for a particular user. I can disable most of the functions of it with Gpedit.msc (Windows XP), but whenever I make the change, it applies to the administrative user also. Is there any way to disable the three finger salute in XP for just the user that is running PWB?
I am running it in kiosk mode, but not as the shell.
Wendell
You can set the following registry keys to disable the Windows Security dialog buttons on a per user basis.
HKCU or HKLM\Software\Microsoft\Windows\CurrentVersion\Policies\System
DisableLockWorkstation
DisableChangePassword
DisableTaskMgr
HKCU or HKLM\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer
NoLogoff
NoClose
Thess are all DWORD values with 1 policy enabled or button disabled and 0 being policy disabled or button enabled.
wgragg
Post by wgragg »
Thanks Scott, but looking down that registry key, I don't see a user identity. Am I missing something?
The easiest way to set the keys is to make the user an administrator, logon as the user, create the keys, the move the user back to a user.
Otherwise you will have to look through the HKEY_USERS key and pick the right user.
wgragg
Post by wgragg »
Ahh, gotcha. One would think that MS would make that a little bit easier! I was wondering if that was the case, but just couldn't believe that they would be that kludgy. Silly me.
Is there anyway to disable the shutdown part of the ctrl-alt-del menu? If patrons can shutdown the computer, they will.
Thanks, Wendell
If you set the NoClose key to 1 the shutdown button will be disabled.
PWB actually had this functionlity built in until we discovered it was not going to work becuase users only have read access to the keys.
