AOL Problems
amutch
AOL Problems
Post by amutch »
I'm trying to determine if this is an issue with PWB or something else on my PC. I'm running PWB 2.06 on Windows 2000. On one PC running PWB, when users try to access their AOL accounts via AOL's web site, it fails to log them in. Typically, it leaves them at a white screen. On other PCs running PWB, it works fine and all PCs use the same INI file. So it doesn't seem like it should be a problem with PWB. But perhaps there's some conflict between a setting on this PC and PWB.
Has anyone else seen this problem or have any suggestions on what might be causing it?
Since it is happening on one machine and not others, try clearing the IE cache by using the Internet Options Control Panel applet. The IE cache can get to large and cause this type of problem.
