PWB closes with an error when a second window is opened.
Mark Kaczmarek
Post by Mark Kaczmarek »
Having a problem with PWB 2.0.3 that when a second window is opened PWB closes with an error to send to MS. This only happens the the second window and it does the same when logged in as administrator and restricted user.
I downloaded the PWB 2.03 version 1 but that did not help.
Any help is greatly appreciated
Mark
Mark Kaczmarek
Owner
MarkTek Consulting
marktekconsulting@yahoo.com
What are the specs on your computer, OS, and IE versions?
Please send a copy of your INI file to...
Support@TeamSoftwareSolutions.com
Mark Kaczmarek
We are currently running Windows XP and IE is 6.0.2600.0000.
The PWB ini follows:
RegisteredTo=
RegistrationNumber=
IniFileVersion=2.03
Title=Public Web Browser v2 - Pinckney Community Public Library
KioskMode=False
DesktopMode=False
HomePage=www.yahoo.com
CommandLineHomePage=False
SearchPage=www.google.com
WebMailPage=
AddressBarText=Address:
DefaultFontSize=2
DefaultSendLink=True
StartMaximized=True
AlwaysOnTop=False
WindowHeight7=
WindowWidth=
WindowTop=
WindowLeft=
ShowMenuBar=True
ShowToolBar=True
ShowShellBar=False
ShowAddressBar=True
ShowAnimation=True
ShowStatusBar=True
ShowTitleBar=True
ShowBackButtonMenu=True
ShowInactivityTimer=True
ShowActivityTimer=True
ShowStatusBarTime=False
ShowURLInBrowserCaption=True
DisableMinimizeButton=False
DisableMaximizeButton=False
DisableCloseButton=False
DisableMoveWindow=False
DisableResizeWindow=False
DisableNewWindow=False
DisableScriptErrorSuppression=False
DisableINIVersionCheck=False
DisableExit=False
ConfirmClose=False
[SecondWindow]
AlwaysOnTop=False
LimitCount=
DisableTitleBar=False
WindowHeight=
WindowWidth=
WindowTop=
WindowLeft=
NewPageAsHome=False
[ToolBars]
MenuBarGripper=Fals
ToolBarBreak=True
ToolBarGripper=False
ToolBarChevron=True
ShellBarBreak=False
ShellBarGripper=False
ShellBarChevron=True
AddressBarBreak=True
AddressBarGripper=False
MenuBarWidth=
ToolBarWidth=
ShellBarWidth=
AddressBarWidth=
[Printer]
ShowPrintButtonDialog=False
ForcePrintPreview=False
UseLimitPrintJobs=False
LimitPrintJobs=0
PrintJobLimitTitle=Print Limit
PrintJobLimitMessageFile=.\PrintLimit.txt
[Dialogs]
DialogSeconds=20
PolicyTitle=Policy.txt
AccessTitle=Warning: Denied
ConfirmCloseDefaultNo=True
ConfirmCloseTitle=Confirm Close
PolicyHeight=
PolicyWidth=
ConfirmCloseSoundFile=
AccessDeniedSoundFile=
WorkingAnimation=
PolicyFile=\\S-pcpl-pdc\PWB\Policy.txt
HistoryFile=.\History.txt
CheckURLFile=
CheckIPFile=
PopupAdFile=
AccessMessageFile=.\Access.txt
ConfirmCloseMessageFile=.\ConfirmClose.txt
SaveAsErrorMessageFile=.\SaveAsError.txt
DownloadErrorMessageFile=.\DownloadError.txt
FavoritesFolder=.\Favorites
ShellBarFolder=.\ShellBar
StartupScript=
ShutdownScript=
PolicyDeclineScript=
DesktopFile=
SendToApp=
[Directories]
SaveAsDirectory=A:\
SaveAsErrorTitle=Floppy required
DownloadDirectory=
DownloadErrorTitle=Floppy required
[RestrictedSave]
EnableRestrictedSave=True
SaveToTitle=Save To...
SaveToDrives=ADH
SaveToDriveError=Please insert a disk.
DisableFileDownload=False
StationEnviromentVariable=COMPUTERNAME
WriteHistoryFile=False
TrackURL=False
CheckURLAccess=False
CheckIPAccess=False
ClosePopupAds=True
ShowAccessDialog=True
LogAccess=False
ClearCacheOnHome=True
ClearCacheOnClose=True
DisableAddressDropDown=False
DisableContextMenu=False
UseCustomContextMenu=True
ShowPolicyDialog=True
OnlyAccessHTTP=True
DisableSecondInstance=False
RestartOnClose=False
[Overrides]
ExitBrowser=exit
Logoff=logoff
Shutdown=shutdown
ResetActvityTime=resettime
ResetPrintLimit=printlimit
[Inactivity]
InactivitySeconds=1200
InactivityMessageFile=.\Inactivity.txt
InactivityAction=Exit
InactivitySoundFile=
InactivityStartOnOpen=False
[Activity]
ActivityTimer=False
ActivitySeconds=1800
ActivityMessageTitle=Warning
ActivityMessageFile=.\Activity.txt
ActivityWarnAt=120
ActivityWarnTitle=Warning
ActivityWarnMessageFile=.\ActivityWarn.txt
ActivityAction=Exit
ActivitySoundFile=
ActivityStartOnOpen=False
[Proxy]
UseCustom=False
ProxyEnable=
ProxyServer=
ProxyOverride=
AutoConfigURL=
[PageSetup]
UseCustom=False
Footer=&u&b&d
Header=&w&bPage &p of &P
MarginBottom=0.75000
MarginLeft=0.75000
MarginRight=0.75000
MarginTop=0.75000
Duplex=1
Orientation=1
[Buttons]
Back=True
Forward=True
Separator1=False
Stop=True
Refresh=True
Home=True
Separator2=True
Search=True
Favorites=True
Print=True
PrintPreview=False
Separator3=False
Send=False
WebMail=False
Separator4=False
About=False
Policy=True
Separator5=True
New=False
Save=False
Separator6=False
Cut=False
Copy=False
Paste=False
Find=False
TextSize=True
[MenuItems]
FileMenu=True
FileNew=True
FileOpen=True
FileSaveAs=True
FileSeparator1=True
FilePageSetup=True
FilePrintPreview=True
FilePrint=True
FileSeparator2=True
FileSend=False
FileSendFile=False
FileSendLink=False
FileSeparator3=True
FileProperties=True
FileExit=True
EditMenu=True
EditCut=True
EditCopy=True
EditPaste=True
EditSeparator1=True
EditSelectAll=True
EditSeparator2=True
EditFind=True
ViewMenu=True
ViewToolbar=True
ViewStatusBar=True
ViewSeparator1=True
ViewGoto=True
ViewGotoBack=True
ViewGotoForward=True
ViewGotoHome=True
ViewGotoSearch=True
ViewStop=True
ViewRefresh=True
ViewTextSize=True
ViewTextSizeLargest=True
ViewTextSizeLarge=True
ViewTextSizeMedium=True
ViewTextSizeSmall=True
ViewTextSizeSmallest=True
ShellMenu=False
FavoritesMenu=True
HelpMenu=True
HelpPolicy=True
HelpAbout=True
[ContextMenu]
OpenLink=True
OpenLinkNew=True
SaveTarget=True
PrintTarget=True
Separator1=True
ShowPicture=True
SavePicture=True
SetWallPaper=True
SetDeskTopItem=False
Separator2=True
Cut=True
Copy=True
CopyShortcut=True
Paste=True
Separator3=True
Encoding=True
Separator4=True
Properties=True
[URLKeys]
EnableURLKeys=False
A1=www.google.com
Mark
Mark Kaczmarek
Owner
MarkTek Consulting
If you are using the pop-up filter...
ClosePopupAds=True
You must specify the pop-up ad filter file.
PopupAdFile=
