File Extensions "URL.txt.txt"
Is your PWB.INI file or URL.txt filter not working?
Here is a helpful hint that may save some trouble. When editing files with known extensions, such as configuration files (INI), or text files (.txt), it is usually not neccesary to add the extension (.INI, .txt) to the file name. If you have the "Hide extensions for known file types" check in the Fodler Options the extension is hidden and the file that was supposed to be "URL.txt" could be named "URL.txt.txt".
This setting is located in Windows Explorer on the Tools, Folder Options, View tab.
