Help A Newbie
cceller
Help A Newbie
Post by cceller »
Hi -
We will be using PWB to lock down our PAC machines here in our library.
I think I have most of the things I want locked down, but I am having issues with such things as CTRL+ALT+DEL, access to the start menu, CTRL+ESC.
I have tried some of the tips here, to no avail.
Any suggestions?
Is it possible to make PWB the shell, as opposed tp Window's default of Explorer? Has anyone tried this and if so, what experiences did you have?
Chad
To disable the Ctrl-Alt-Del Windows Security dialog buttons see the following post.
http://teamsoftwaresolutions.com/phpBB2 ... .php?t=110
To disable the Ctrl-Esc, you can either run PWB as the shell, or you can use the PWB add-on PWBHideWindowsGUI.
