disable mailto
sheila1117
disable mailto
Post by sheila1117 »
I would like to disable all "mailto" links using pwb.
Is this possible?
There are a few ways you can do this.
You can disable all the MailTo: links by removing the MailTo: association in the registry. This is done by setting the following resgistry key to blank.
[HKEY_CLASSES_ROOT\mailto\shell\open\command]
If you want to allow emails in a secure way, you can use a secure email client, such as the SendTo or the SendComment applications available on our Download page.
http://www.teamsoftwaresolutions.com/downloads.html
Or you can use the PWB URL filter to prevent access to MailTo: by enabling the URL filter, and denying access to "MailTo:".
Enable the URL filter:
CheckURLAccess=True
Add this in your URL Filter file:
-mailto:
This will prevnet access to the MailTo: links.
sheila1117
Thanks so much! I disabled it in the registry and it works great!
Sheila
