Foreign Language Input support
mbhamp
Post by mbhamp »
When browsing www.iu.edu.sa in IE & changing the input language to Arabic, one can input a search string in Arabic. However, when viewing with PWB the input language does not switch. Is there a setting I need to change, or is this not supported? Using PWB 2.08
This should now be working in PWB v2.08.1 which is currently being beta tested. Please see the following post for more information.
http://teamsoftwaresolutions.com/phpBB2 ... .php?t=519
ShanWic
Post by ShanWic »
Hi Scott, I'm running Ver 2.10.9 and still have the same issue with setting the input language. It's working for all other applications including Internet explorer. The language changes in the language bar but the input is not changing. Any advice ?
Are you using kiosk mode?
The language bar is hidden when running PWB in kiosk mode.
