ALT+F4
butters
ALT+F4
Post by butters »
In Kiosk mode can you use ALT+F4 to exit the program? We are experimenting with Kiosk mode IE 6 and the only way to close PWB is to end the task in the task manager!
In PWB v1:
DisableExitOverride=close
Override disable exit command. Commands for overriding exit functions, Typed over Author in About dialog box.
butters
Post by butters »
We are using the defaults here. Can you clarify what you mean?
UserName=user
Password=password
KioskOverride=exit
LogOffNTOverride=logoff
ShutDownWin9xOverride=shutdown
Login=False
Policy=False
PolicyDialogHeight=
PolicyDialogWidth=
WriteHistory=False
Track=False
ShowScriptErrors=True
NoAccess=False
NoAccessMessageSeconds=20
NoAccessMessage=Operation Canceled due to restrictions on this computer
NoAccessMessageTitle=Public Web Browser
OnlyAccess=False
OnlyAccessMessageSeconds=20
OnlyAccessMessage=Operation Canceled due to restrictions on this computer
OnlyAccessMessageTitle=Public Web Browser
CheckAccessBeforeBrowse=True
CheckAccessAfterBrowse=False
DebugAccessString=False
OnDenyAccess=
CheckIP=False
ShowDenyAccessDialogs=True
Click on the About button, or on the Help About to display the About dialog. On the About dialog there is a hidden edit box where the Authors name is. Highlight the authors name and type the override into the hidden edit box. This will enact the override, in this case you would want to use the disable exit override.
butters
Post by butters »
Thanks for clarifying that. Pretty easy to do, I guess my brain was not working right. :?
