Troubleshooting the Inactivity timer
GregP
Post by GregP »
I was wondering if you can advise me on something to do with the Inactivity timer. We want our catalogue PCs to reboot after 5 minutes of inactivity, and the settings below are doing the job, but there is an annoying side effect.
Even when the computer has just turned on, with no-one having used it, it reboots after 5 minutes. I would have assumed the entry InactivityStartOnOpen = False would have fixed my problem but it doesn't.
Any ideas, or does the timer not work like that?
[Inactivity]
InactivityTimer=True
InactivitySeconds=300
InactivityMessageFile=c:\pwb\Inactivity.html
InactivityAction=Reboot
InactivitySoundFile=
InactivityStartOnOpen=False
InactivityShowDialog=True
ResetOnMouseMove=True
ResetOnMouseButton=True
ResetOnKeyboard=True
What is your home page set to?
If the home page does any kind of navigation, PWB can not distinguish between a redirection or auto navigation and a user requested navigation, and this will start the inactivity timer.
GregP
Post by GregP »
Thanks Scott,
I'll look into that. Would a cgi script count?
I think there is a simple re-direction which I can probably eliminate, but our Library Management System generates most pages in response to a CGI query.
Ta,
GregP
A CGI script is done while the page is loading, this will not affect the timer. PWB waits until the home page is loaded then sets a trip to wait for the next page to load before starting the timer. The home page loads, the trip is set, and if the home page redirects the time starts.
GregP
Post by GregP »
Thanks Scott,
I've eliminated the redirect and our problem is solved.
GregP
