Shellbar Icons Not Showing
Alex Weeks
Post by Alex Weeks »
PWB runs automatically from the Run registry key for our OPAC user. When run this way the shellbar icons in the Shellbar folder do not show. If we run PWB manually after logging in, they show with no problems.
Any ideas why?
Alex.
Change the Shellbar folder in the INI file to include the full path. When running PWB as the Windows shell, the current directory will not be the PWB folder. If you do not use the full path for the Shellbar folder in the INI file PWB will not be able to locate the Shellbar shortcuts.
Alex Weeks
Works a treat. Thanks!
Alex.
