Hey Scott,
I saw 2.08.3 was out and the file date on the ini file had changed to Aug 25th. Can I use my 2.8.0 ini file with 2.08.3 or do I need to change that?
Any chance you could post the announcment about the upgrade and what it so we can decide whether to upgrade our machines?
Rick
2.08.3 question
Yes you can use your current 2.08.x INI with PWb v2.08.x. The minor revisions do not contain any official INI changes.
PWB v2.08.2 and PWB v2.08.3 have very minor changes that are documented in the ReadMe. We normally post the changes in the announcement section of our forums but we got a little lax this time, I appologize for any inconvenience this may have caused.
Version 2.08r2 09-19-2005
Bug that may cause an error if PWB is exited when an IE plug-in is active.
Version 2.08r3 09-29-2005
Support Cut/Copy/Paste Shockwave plug-in for Tutor.com
Speaking of announments, we are currently testing PWB v2.08.4 which contains the following minor fixes.
Version 2.08r4 10-14-2005
Fixed/Changed
Fixed poissble error with windows.external = null
Fixed Windows XP Security bar resizing problem
Fixed window closing in JavaScript popup close function
There will be several additions to the up and coming PWB v2.09 which includes features documented in the ReadMeBeta.txt file. The major feature planned for PWB v2.09 is support for IE BHOs, which would include the Google toolbar.
Fixed/Changed
