e-vancedsolutions.com calendar not working
tloga
Post by tloga »
The Next and Previous Month links in our events calendar (from http://www.e-vancedsolutions.com) are not working.
We are on PWB v2.08r4
Our calendar is at calendar.mppl.org
Any ideas?
The calendar works with a stock INI file.
I assume the post about the rebooting problem contains the same INI file you are using, what is in you URL filter file?
Because you do not have an access message file listed in the INI file you will not get the access message when the page is denied.
AccessMessageFile=
I think you probably have a string in the URL filter file that is prevent access to the Next and Previous links on your calendar page.
tloga
Post by tloga »
That was it -- we adjusted the URL.TXT file and it was fixed.
THANKS
