Setting up the Proxy
Bahem
Post by Bahem »
Do you need to set both
UseCustom=True
and
ProxyEnable=True
to set the proxy?
Bahem
"I'd give my right arm to be ambidextrous."
Yes, the Use Custom setting enables PWB to set the proxy, the Enable Proxy actually enables the IE proxy. We put in both settings because someone may want to disable the IE proxy when running PWB by using the custom proxy with the proxy disabled.
