Windows XP SP2 and running an EXE from a server.
If you are running an EXE from a server with Active Directory using Windows XP SP2 you may encounter the following dialog.
"The publisher could not be verified. Are you sure you want to run this software?"
To disable this dialog set or add the following string in the Windows Registry.
[HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Associations]
"LowRiskFileTypes"=".exe"
Please note:
You can use this setting in either the HKEY_CURRENT_USER or HKEY_LOCAL_MACHINE.
If this key is already there, add ";.exe" to the end of the key value.
If more then one file type is added, separate with a semi-colon.
You may need to log off and back on for the setting to take effect.
Warning:
Use at your own risk. If you use Registry Editor incorrectly, you may cause serious problems that may require you to reinstall your operating system.
