Problem with screen painting
rheckber
Post by rheckber »
I am running v2.09.3 on an XP machine and I am trying to run it in kiosk mode. When I set kioskmode=true and start PWB there is a problem with screen painting in the toolbar area. At first the whole top of the screen was missing. Not sure what I did to fix that but now what I still am having a problem with is the back and forward button graphics. Where the buttons go for those two I have a see through box and can still see the desktop and any icons there (whatever is under PWB). If I navigate to any page the back button shows up (I assume because back now has a meaning?) If I play around some more the forward button shows up. However, I am still missing a small vertical rectangle the same height as the buttons just to the left of the back button graphic no matter how I navigate. This is the only thing holding me up deploying this machine.
Please send a copy of your INI file to Support@TeamsoftwareSolutions.com.
There may be a combination of settings in your INI file causing it. I we find a combination of settings causing the problem we can fix it or suggest a work around. If we find anything I will post it back to this thread.
