Is it possible to disable the text the pops up when you put the mouse cursor over an image? We use PWB in a few displays with a program that hides the mouse cursor. Every so often, an image loads under the invisible cursor, causing the description box to appear, sometime flickering (probably because of the cursor hider program). Is there anyway to disable this box? Thanks.
Anthony
Disable image descriptions
