Display problems with shell bar
jsand
Post by jsand »
I'm having an odd problem with my toolbar. I've got two items on the shell bar - Editor and Logoff. When I run the workstations in 1024x768, everything is fine. The shellbar is immediately to the right of the last toolbar button. But when I set the display to 800x600 (which is the production environment) the shellbar gets condensed all the way to the right side of the screen into an arrow you need to click to get to the icons. What gives? A copy of the .ini file is at http://www.villapark.lib.il.us/jeff/PWB.INI.txt. Running 2.09.3
Becuase you have disabled the resizing of the toolbars by setting the grippers to false, PWB is setting the toolbar as a fixed width. You can adjust the widths by setting the following in your INI file.
[Toolbars]
ToolBarWidth=100
ShellBarWidth=100
