manageIE and setpwb
sraymond
manageIE and setpwb
Post by sraymond »
Hi I have been reading the posts on blocking access to IE through other applications, in our case, it's Word. Patrons can click on a link in a Word doc and open IE. We, too would prefer PWB open. I have downloaded ManageIE from the beta directory and SetPWB from the Downloads directory. I have unzipped then and I _believe_ I have installed them, too. I have checked the registry and the modifications described in the readme files seem to have been made, but still IE is opening. For what it's worth I am doing all this in an administrative account. I am confused. To stop IE from opening and force PWB to open, should I be using one or both of these? What step am I missing? appreciatively, -smr
-smray
SetPWB sets PWB as the default browser. This does not prevnet applications from opening Internet Explorer directly.
ManageIE will prevent Internet Explorer from opening.
To get PWB to open instead of PWB merge the "ManageIE.reg" file into your Windows Registry by double clicking on it. You will have to be logged on as an Adminstrator for the file to be merged.
After merging the "ManageIE.reg" file into your registry, open REGEDIT and and change the following value to "1".
[HKEY_LOCAL_MACHINE\SOFTWARE\TeamSoftware Solutions\ManageIE]
OpenPWBToURL
This will cause ManageIE to open PWB when an application attempts to navigate to a web site.
sraymond
Excellant!
Post by sraymond »
ManageIE is now accomplishing exactly what I'd hoped it would! Thanks Scott! Now, however as a result of my blind flailings to stop IE from opening, I have setPWB to run in the network admini account. Now that ManageIE is doing the trick, I don't think I will need setPWB at all. How can I uninstall or modify the registry so that setPWB is no longer functioning? thanks a bunch! -smr
-smray
All SetPWB does is to modify the registry for the current user to set PWB as the default. If you want IE to be the default web browser for the current user, run IE and let it set itself back.
http://support.microsoft.com/kb/284456
sraymond
Post by sraymond »
But how do I get IE to run when there is nothing on the desktop if I close PWB, start menu is inaccessible. PWB is off and Fortres, too. Can I edit the registry from the local admin account?
-smray
The changes made are account specific. If you do not want IE to run for the profile, then leaving the changes will not hurt and will probably help.
sraymond
Post by sraymond »
The problem is I DO want IE to run in this account, it's the network admin. How do I stop setPWB from running in that account? appreciativley, -smr
-smray
Do not run SetPWB from where you are running it, logon as the user and run Internet Explorer. Internet Explorer will see it is not the current browser and reset itself.
sraymond
Post by sraymond »
The problem is I cannot get IE to run in that account. The question is how do I stop setPwb from running, it seems to start automatically. I am ready to reformat the darned machine.
-smray
sraymond
Post by sraymond »
Problem solved. I deleted the network admin account as well as its entire directory in Docs and Settings. Then I created an entirely new Network admin account. phew
-smray
SetPWB does not run unless you are running it from somewhere. The settings it makes are to the few registry locations to associate PWB as the default web browser. Running Internet Explorer by clicking directly on the Internet Explorer shortcut or EXE will run Internet Explorer and Internet Explorer will reset itself to the default web browser.
Or you can delete the profile and let Windows recreate it as well.
