Clearing temp files
SusanS
Clearing temp files
Post by SusanS »
Could PWB be made to clear temp files, just as it clears the cache? Or, am I missing a setting in the .ini file. Currently using 2.03. Love it!!!
Use the shutdown or startup script to delete any folders you need to.
We use a solution similar to this:
http://www.spoo.net/pro/pwb-privacy.htm
It mostly involves a simple .bat file for clearing the temp files and using CLearIECache. Set both up as shell buttons, and patrons can control their own privacy level.
ramone_johnny
Post by ramone_johnny »
We use the following configuration within the INI file which points to a .BAT located on the server.
ShutdownScript=\\***.***.***.***\pwb_profiles\internet\removecookies.bat
*removecookies.bat*
@DEL "%USERPROFILE%\COOKIES\INTERNET*.*" /Q
HTH
John
