Hi: Im using PWB in Windows NT Terminal Server with Citrix Metaframe 1.8, every 10 mins (i think) i obtain the following error message:
Dr Watson for Windows NT:
An Application error has occurred
PWB.EXE Exception: access violation (0xc0000005) Address: 0c00414a1d
Im lawnching pwb using runapp.exe when the user logs on
What happen??
Desa
PWB.EXE DrWatson error in Windows NT Terminal Server
Desa
DrWatson error in NTTSE PWB
Hi: Im dont using a registered version, i testing. Uson pwb 2.03
when i want to install 2.04 version have a MSIInstaller error in Widnows NT TS
Use the manual install for PWB v2.04. The installer only copies the files to the specifed folder and creates the Start Menu shorcuts. Using the manual install, simply unzip the archive to the folder you want and create your own shortcuts.
Or you can use the installer for Windows 98. This installer installs the newest Microsoft Installer then installs PWB.
You will still have the 10 minute unregistered limitation but not the error. If you would like to receive a 30 day temporary registration number please email Michelle@TeamSoftwareSolutions.com.
