We have a link on a web page that is supposed to call a javascript function to open a new window. This works in IE even when the highest level of pop-up blocking is enabled. But in PWB (2.09.3), it generates a blank window. The odd thing is that if you do a right-click on the link that calls the function, it will open correctly in a new window (select open link in new window if you get a context menu). The link is located on this page:
http://twp.waterford.mi.us/gis/
click on the globe image as this in the link that calls the javascript function.
Andrew
odd pop-up behavior
Here is what we have found so far.
The function in the web page is resizing the new window.
The Internet Explorer web browser control PWB is using does not seem to support this in a new window.
However PWB does support it in the same window. Changing the code to the following works.
As a work around you can have the new window open to the map page and have the map page resize the browser.
We are looking for a fix correct the problem directly.
function newMapWin() {
newWaterfordTwpWin=window.open("","WaterfordTwpMapWindow","toolbar=no,location=no,status=yes,resizable=yes");
var scrWidth=[b]screen.availWidth[/b];
var scrHeight=[b]screen.availHeight[/b];
[b]newWaterfordTwpWin.moveTo[/b](0,0);
[b]newWaterfordTwpWin.resizeTo[/b](scrWidth,scrHeight);
newWaterfordTwpWin.document.location="http://maps.twp.waterford.mi.us/Viewer.htm";
function FullWindow()
var scrWidth=screen.availWidth;
var scrHeight=screen.availHeight;
top.window.moveTo(0,0);
top.window.resizeTo(scrWidth,scrHeight);
