Is it possible to have an Inactivity Timer set only for the Second window and have no effect on the Primary Window?
If yes, which settings in the INI file show I change?
Thank you.
Inactivity Timer for Second Window only?
The only way you could do this is to have one PWB launch another. This would allow the first instance of PWB to not have a timer, but the second instance to. There are a few settings that can help acheive this.
[SecondWindow]
OpenInNewProcess=True
[Java]
JavaExecute=StartPWB
You may also want to look into the PWB Desktop mode.
[SecondWindow]
[Java]
Thanks for the quick reply. I need more info though...
If I use
[SecondWindow]
to launch the second window,
what INI setting should I use so that only the second window has a timer?
Or rather, how do I tell the second instance of the PWB browser to use a different INI file so that only the second window has a timer?
Thanks again
If I use
[SecondWindow]
Thanks again
You would have to use some tricky batach files, it would be easier to use the Dynamic External Java commands to launch a second instance of PWB either with a command line URL or form a different folder.
[Java]
Here is an example of the java commands:
http://www.teamsoftwaresolutions.com/beta/external.htm
[Java]
