Inactivity Timer for Second Window only?
Vincent Mak
Post by Vincent Mak »
Is it possible to have an Inactivity Timer set only for the Second window and have no effect on the Primary Window?
If yes, which settings in the INI file show I change?
Thank you.
The only way you could do this is to have one PWB launch another. This would allow the first instance of PWB to not have a timer, but the second instance to. There are a few settings that can help acheive this.
[SecondWindow]
OpenInNewProcess=True
[Java]
JavaExecute=StartPWB
You may also want to look into the PWB Desktop mode.
Vincent Mak
Thanks for the quick reply. I need more info though...
If I use
[SecondWindow]
to launch the second window,
what INI setting should I use so that only the second window has a timer?
Or rather, how do I tell the second instance of the PWB browser to use a different INI file so that only the second window has a timer?
Thanks again
You would have to use some tricky batach files, it would be easier to use the Dynamic External Java commands to launch a second instance of PWB either with a command line URL or form a different folder.
[Java]
Here is an example of the java commands:
