When i hit alt+tab or cntrl+alt+del or other key combinations I am able to bypass the PWB, how can i stop this from happening? '
Also I cant seem to figure out how to close it down the right way, what is the secret to get my exit password to prompt?
Disable any exit from PWB
Preventing Alt-Tab you will need to use another application, for example HideGUI available on our Download page.
Here is a guide that uses HideGUI to only allow access to PWB:
http://www.teamsoftwaresolutions.com/ph ... .php?t=536
You can also try the hidden feature in PWB v2.10.8 SecureMode. This is enabled by adding "SecureMode=True" to the [Browser] section of your INI file.
To get the overrides prompt, press Ctrl-Alt-Shift + Insert on your keyboard. The keyword is cases sensitive. Please see the PWBv2.rtf file in the PWB folder for more information on the overrides.
