Disable any exit from PWB
anythinkLibraryIT
Post by anythinkLibraryIT »
When i hit alt+tab or cntrl+alt+del or other key combinations I am able to bypass the PWB, how can i stop this from happening? '
Also I cant seem to figure out how to close it down the right way, what is the secret to get my exit password to prompt?
Preventing Alt-Tab you will need to use another application, for example HideGUI available on our Download page.
Here is a guide that uses HideGUI to only allow access to PWB:
You can also try the hidden feature in PWB v2.10.8 SecureMode. This is enabled by adding "SecureMode=True" to the [Browser] section of your INI file.
To get the overrides prompt, press Ctrl-Alt-Shift + Insert on your keyboard. The keyword is cases sensitive. Please see the PWBv2.rtf file in the PWB folder for more information on the overrides.
