In your INI file, use the full paths to the files for PWB. For example if your files are located in the folder C:\PWB set your INI file like this.
CheckURLFile=C:\PWB\URL.txt
AccessMessageFile=C:\PWB\Access.txt
This will ensure PWB will be able to find the files.
						New Internet Explorer Window launches when a link is selecte
I have emailed you as much details as possible for this.  Let me know when you receive it and if you need anything more.  Although that was before I followed your recommendations to add the full paths.
After adding the full path it is working better. It comes up with no errors.
Except it is opening in a new PWB. Is it possible to force this to open to the Parent PWB Page, instead of a new instance of PWB?
