How can i disable compatibility view in IE 8? PWB version is 2.04 User agent string.com still points to the following information.
MSIE 7.0 Internet Explorer version 7.0 (MSIE 8.0 in 7.0 compatibility view)
http://www.teamsoftwaresolutions.com/fo ... php?t=1177
I tried editing the registry as posted in the above link for all users. But got same error.
How to set IE in standar mode? Thank you.
disable compatibility view in IE8
Re: disable compatibility view in IE8
You should upgrade to the newest version of PWB version 2.10.8 and leave the following setting empty.
IEBrowserEmulation=
IEBrowserEmulation=
Do i have to buy additional license to upgrade? Is there tutorial for upgrading pwb? thank you,
The upgrade is free.
Here are the instructions:
http://www.teamsoftwaresolutions.com/fo ... ?f=1&t=709
Hi Scot, Cant seems to find IEBrowserEmulation = . I have upgraded to 2.11 but did a search for IE browser.
ommandLineHomePage=FALSE
SearchPage=
WebMailPage=
AddressBarText=Address:
DefaultFontSize=2
DefaultSendLink=TRUE
StartMaximized=FALSE
AlwaysOnTop=FALSE
WindowHeight=-1
WindowWidth=-1
WindowTop=-1
WindowLeft=-1
ShowMenuBar=TRUE
ShowToolBar=TRUE
ShowShellBar=FALSE
ShowAddressBar=TRUE
ShowAnimation=FALSE
ShowStatusBar=TRUE
ShowTitleBar=TRUE
ShowBackButtonMenu=TRUE
ShowInactivityTimer=TRUE
ShowActivityTimer=TRUE
ShowStatusBarTime=TRUE
ShowURLInBrowserCaption=TRUE
DisableMenuBarMove=False
DisableToolBarMove=True
DisableShellBarMove=True
DisableAddressBarMove=False
DisableMinimizeButton=FALSE
DisableMaximizeButton=FALSE
DisableCloseButton=FALSE
DisableMoveWindow=FALSE
DisableResizeWindow=FALSE
DisableNewWindow=FALSE
DisableScriptErrorSuppression=False
DisableINIVersionCheck=FALSE
DisableExit=FALSE
ConfirmClose=FALSE
ConfigRegLocation=
UseIEFavorites=FALSE
ShowGoButton=FALSE
GoButtonText=Go
AlwaysOnBottom=FALSE
DisableIESubClass=FALSE
ShowWindowRelation=FALSE
MainWindowIndicator=(Main)
ShowKioskBar=FALSE
F1HelpPageURL=
ShowSplashScreen=FALSE
DisableAutoComplete=FALSE
ShellExecuteScripts=FALSE
OpenLinksInNewWindow=FALSE
DisableCtrlEnter=FALSE
SaveWindowPosition=FALSE
MinimizeMemoryUsage=FALSE
StartTimersOnMouseKeyboard=FALSE
AddStationToUserAgent=FALSE
UpdateWindowOnTime=FALSE
RedrawWindowSeconds=-1
EnableAdvancedClose=FALSE
DisableScrollBars=FALSE
MapContextPrintToButton=FALSE
PreventHTMLClosingMainWindow=FALSE
AddressBarReadOnly=FALSE
ShowAddressInBrowserCaption=FALSE
MaximizeOnNonsizeable=FALSE
SecureMode=FALSE
HideCursor=FALSE
ExitPage=
ShowSearchBar=FALSE
SearchBarText=
SearchBarPage=
StatusBarTimeFormat=
StatusBarTimeWidth=32
SearchPage=
WebMailPage=
DefaultFontSize=2
AlwaysOnTop=FALSE
WindowHeight=-1
WindowWidth=-1
WindowTop=-1
WindowLeft=-1
ShowMenuBar=TRUE
ShowToolBar=TRUE
ShowShellBar=FALSE
ShowAddressBar=TRUE
ShowAnimation=FALSE
ShowStatusBar=TRUE
ShowTitleBar=TRUE
DisableExit=FALSE
ConfirmClose=FALSE
ConfigRegLocation=
ShowGoButton=FALSE
GoButtonText=Go
ShowKioskBar=FALSE
F1HelpPageURL=
SecureMode=FALSE
HideCursor=FALSE
ExitPage=
ShowSearchBar=FALSE
SearchBarText=
SearchBarPage=
If you the setting is not in your INI file it will default to native IE mode in version 2.11.*.
If you want to set PWB to compatibility mode add the setting to your INI file.
If you visit the following URL it will tell you if you are in compatibility mode.
http://www.whatismybrowser.com/
Hi Scott, After upgrading INI to 2.11 using PWBINI.exe and copying PWB.exe to PWB folder I am getting the following error on my test machine.
The wrong version of INI file was used.
The INI is returning 2.11 as the version. THe version of PWB requires 2.04 of the ini file. Check your INI file and try again
Is there something missing? Can you please check.
You did not follow steps 8 and 9 to replace your PWB executable version 2.04 with version 2.11.
Hi Scott, I did copy new pwb.exe from the upgrade folder which i downloaded from your website. I tried it 2 today and got the same error.
Please See the attach file for time stamp. Screen shot from test machine.
- ScreenHunter_31 Nov. 12 16.15.jpg (7.77 KiB) Viewed 151946 times
The error message you are indicating...
Please check the shortcut that is starting PWB to ensure it is pointing to a PWB.EXE version 2.11 executable.
If the INI file was not updated and you were using PWB 2.11 the message would be reversed.
...says the INI file is 2.11, but the EXE is 2.04.The wrong version of INI file was used.
The INI is returning 2.11 as the version. The version of PWB requires 2.04 of the ini file. Check your INI file and try again
- 204.PNG (11.84 KiB) Viewed 151944 times
Hi Scot, I have disabled compatibility mode from PWB by adding IEBrowserEmulation=
but it wont take it. I have disabled it from IE 8, edited registry but still nothing. PWB browser still running in Compatibility mode which is causing issues with catalog.
Any help will be really appreciated.
Thank you.
Thank you.
What version of PWB are you using?
If you are using IE 8.0 you should upgrade to a newer version of IE since most sites are no longer compatible with IE 8.0.
