We've been using PWB for years now, and haven't had this error before. So, I'm not sure where/what is causing it. When patrons go to Ancestry.com through PWB, a bunch of boxes pop up
I can click on Details for further information which is:"Cannot start application" with the message "Cannot continue. The application is improperly formatted. Contact the application vendor for assistance."
PLATFORM VERSION INFO
Windows : 6.1.7601.65536 (Win32NT)
Common Language Runtime : 4.0.30319.34209
System.Deployment.dll : 4.0.30319.34280 built by: FX452RTMGDR
clr.dll : 4.0.30319.34209 built by: FX452RTMGDR
dfdll.dll : 4.0.30319.34280 built by: FX452RTMGDR
dfshim.dll : 4.0.41209.0 (Main.041209-0000)
SOURCES
Deployment url : https://www.ancestry.com/lp/cross-domain-cookie?OPTOUTMULTI=0%3A0%7Cc3%3A0%7Cc1%3A0%7Cc2%3A0%7Cc5%3A0
ERROR SUMMARY
Below is a summary of the errors, details of these errors are listed later in the log.
* Activation of https://www.ancestry.com/lp/cross-domain-cookie?OPTOUTMULTI=0%3A0%7Cc3%3A0%7Cc1%3A0%7Cc2%3A0%7Cc5%3A0 resulted in exception. Following failure messages were detected:
+ Exception reading manifest from https://www.ancestry.com/lp/cross-domain-cookie?OPTOUTMULTI=0%3A0%7Cc3%3A0%7Cc1%3A0%7Cc2%3A0%7Cc5%3A0: the manifest may not be valid or the file could not be opened.
+ DTD is prohibited in this XML document.
COMPONENT STORE TRANSACTION FAILURE SUMMARY
No transaction error was detected.
WARNINGS
There were no warnings during this operation.
OPERATION PROGRESS STATUS
* [9/21/2018 2:18:11 PM] : Activation of https://www.ancestry.com/lp/cross-domain-cookie?OPTOUTMULTI=0%3A0%7Cc3%3A0%7Cc1%3A0%7Cc2%3A0%7Cc5%3A0 has started.
ERROR DETAILS
Following errors were detected during this operation.
* [9/21/2018 2:18:12 PM] System.Deployment.Application.InvalidDeploymentException (ManifestParse)
- Exception reading manifest from https://www.ancestry.com/lp/cross-domain-cookie?OPTOUTMULTI=0%3A0%7Cc3%3A0%7Cc1%3A0%7Cc2%3A0%7Cc5%3A0: the manifest may not be valid or the file could not be opened.
- Source: System.Deployment
- Stack trace:
at System.Deployment.Application.ManifestReader.FromDocument(String localPath, ManifestType manifestType, Uri sourceUri)
at System.Deployment.Application.DownloadManager.DownloadDeploymentManifestDirectBypass(SubscriptionStore subStore, Uri& sourceUri, TempFile& tempFile, SubscriptionState& subState, IDownloadNotification notification, DownloadOptions options, ServerInformation& serverInformation)
at System.Deployment.Application.DownloadManager.DownloadDeploymentManifestBypass(SubscriptionStore subStore, Uri& sourceUri, TempFile& tempFile, SubscriptionState& subState, IDownloadNotification notification, DownloadOptions options)
at System.Deployment.Application.ApplicationActivator.PerformDeploymentActivation(Uri activationUri, Boolean isShortcut, String textualSubId, String deploymentProviderUrlFromExtension, BrowserSettings browserSettings, String& errorPageUrl)
at System.Deployment.Application.ApplicationActivator.ActivateDeploymentWorker(Object state)
--- Inner Exception ---
System.Xml.XmlException
- DTD is prohibited in this XML document.
- Source: System.Xml
- Stack trace:
at System.Xml.XmlTextReaderImpl.Throw(Exception e)
at System.Xml.XmlTextReaderImpl.ParseDoctypeDecl()
at System.Xml.XmlTextReaderImpl.ParseDocumentContent()
at System.Deployment.Application.ManifestValidatingReader.XmlFilteredReader.Read()
at System.Xml.XsdValidatingReader.Read()
COMPONENT STORE TRANSACTION DETAILS
No transaction information is available.
Does anyone know what this means / how to make the connection properly?
Thank you!
t
