faulting application mshtml.dll pwb.exe
hello,
I have 6 machines running pwb as shell on win xpsp3, when I came in this morning, all 6 of them had failed to restart the browser and just had blank desktops..
error log states
Faulting application pwb.exe, version 2.1.0.7. faulting module mshtml.dll
version 7.0.6000.16981. fault address 0x000b2262.
Event ID :1000
Source : Application error
once all of the pc's were restarted everything was fine..
has anyone come accross this problem before ?
many thanks
error log states
Event ID :1000
many thanks
Hi scott
thanks for the reply..
however these are locked down and will not allow access to a flash enabled website, so It cant be that.
pwb is run as shell and it allows users to login to a Remote Application Server or check there OWA email via pwb. this service is hosted by citrix XenApp plugin, this then allows the user to open a browser within the remote session to gain access to the relevant resource. using IE 8 Firefox 3. it is at this point that they will have access to flash enabled websites. this is impossible without going through our R.A.S server.
Any other suggestions ?
many thanks
many thanks
This is still a problem with 2.10.9
AppName: pwb.exe AppVer: 2.1.0.9 ModName: mshtml.dll
ModVer: 7.0.6000.17023 Offset: 000eb391
error report>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>
<?xml version="1.0" encoding="UTF-16"?>
<DATABASE>
<EXE NAME="pwb.exe" FILTER="GRABMI_FILTER_PRIVACY">
<MATCHING_FILE NAME="PWB.exe" SIZE="1496576" CHECKSUM="0xA6E69DB8" BIN_FILE_VERSION="2.1.0.9" BIN_PRODUCT_VERSION="2.1.0.9" PRODUCT_VERSION="2, 1, 0, 9" FILE_DESCRIPTION="Public Web Browser (March 19, 2010)" COMPANY_NAME="TeamSoftware Solutions" PRODUCT_NAME="PWB Application" FILE_VERSION="2, 1, 0, 9" ORIGINAL_FILENAME="PWB.EXE" INTERNAL_NAME="PWB" LEGAL_COPYRIGHT="Copyright (C) 2002-2009 TeamSoftware Solutions" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x1" MODULE_TYPE="WIN32" PE_CHECKSUM="0x176AE2" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="2.1.0.9" UPTO_BIN_PRODUCT_VERSION="2.1.0.9" LINK_DATE="03/19/2010 16:01:06" UPTO_LINK_DATE="03/19/2010 16:01:06" VER_LANGUAGE="English (United States) [0x409]" />
</EXE>
<EXE NAME="mshtml.dll" FILTER="GRABMI_FILTER_THISFILEONLY">
<MATCHING_FILE NAME="mshtml.dll" SIZE="3599872" CHECKSUM="0x666F9A76" BIN_FILE_VERSION="7.0.6000.17023" BIN_PRODUCT_VERSION="7.0.6000.17023" PRODUCT_VERSION="7.00.6000.17023" FILE_DESCRIPTION="Microsoft (R) HTML Viewer" COMPANY_NAME="Microsoft Corporation" PRODUCT_NAME="Windows® Internet Explorer" FILE_VERSION="7.00.6000.17023 (vista_gdr.100222-0012)" ORIGINAL_FILENAME="MSHTML.DLL" INTERNAL_NAME="MSHTML" LEGAL_COPYRIGHT="© Microsoft Corporation. All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x40004" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x375637" LINKER_VERSION="0x60000" UPTO_BIN_FILE_VERSION="7.0.6000.17023" UPTO_BIN_PRODUCT_VERSION="7.0.6000.17023" LINK_DATE="03/11/2010 12:38:53" UPTO_LINK_DATE="03/11/2010 12:38:53" VER_LANGUAGE="English (United States) [0x409]" />
</EXE>
<EXE NAME="kernel32.dll" FILTER="GRABMI_FILTER_THISFILEONLY">
<MATCHING_FILE NAME="kernel32.dll" SIZE="989696" CHECKSUM="0x2D998938" BIN_FILE_VERSION="5.1.2600.5781" BIN_PRODUCT_VERSION="5.1.2600.5781" PRODUCT_VERSION="5.1.2600.5781" FILE_DESCRIPTION="Windows NT BASE API Client DLL" COMPANY_NAME="Microsoft Corporation" PRODUCT_NAME="Microsoft® Windows® Operating System" FILE_VERSION="5.1.2600.5781 (xpsp_sp3_gdr.090321-1317)" ORIGINAL_FILENAME="kernel32" INTERNAL_NAME="kernel32" LEGAL_COPYRIGHT="© Microsoft Corporation. All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x40004" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0xFE572" LINKER_VERSION="0x50001" UPTO_BIN_FILE_VERSION="5.1.2600.5781" UPTO_BIN_PRODUCT_VERSION="5.1.2600.5781" LINK_DATE="03/21/2009 14:06:58" UPTO_LINK_DATE="03/21/2009 14:06:58" VER_LANGUAGE="English (United States) [0x409]" />
</EXE>
</DATABASE>
any suggestions please ?
thank you
EDIT : I have traced the problem to DisableDialogTimer, When this is set to true and an attempt is used to go to a website that is not on the URL.txt then the PWB crashes with the above fault error report, but when the DisableDialogTimer=False the attempt is still blocked by URL.txt but the browser does not crash. Could this be the problem.
many thanks
<DATABASE>
</EXE>
</EXE>
</EXE>
</DATABASE>
thank you
many thanks
OnlineScott
- Site Admin
- Contact:
Thanks for the detective work.
Please send a copy of your INI file as an attachment to support@teamsoftwaresolutions.com and I will look into it.
