Counting PWB Usage
Counting PWB Usage
You can easily count PWB usage with a VBScript from the PWB [Files]StartupScript= setting.
Create a VBScript file and counter file, for example "count.vbs" and "count.txt".
Edit the "count.txt" file and enter a start value such as 1.
Edit the "count.vbs" file and add the following.
Dim TS, FSO, s1
Set FSO = CreateObject("Scripting.FileSystemObject")
Set TS = FSO.OpenTextFile("c:\count.txt", 1)
s1 = TS.ReadAll
TS.Close
Set TS = Nothing
L = (CLng(s1) + 1)
s1 = CStr(L)
Set TS = FSO.CreateTextFile("c:\count.txt", True)
TS.Write s1
TS.Close
Set TS = Nothing
This is directly from the following web site.
http://www.eggheadcafe.com/software/asp ... voice.aspx
Set the "count.vbs' file in the INI file.
StartupScript=count.vbs
If you do not have the following set in your INI file you will need to start "count.vbs" from a batch file.
ShellExecuteScripts=True
Each PWB is started the counter will be incremented by one.
