viewing contents of the hard disk.
User avatar
Philip - Long Beach NY
I know this has been discussed before so forgive me Scott if I forgot what you said but if a patron types in the command: file://C:\ into the address bar the contents of the drive will be shown. Is this a PWB issue or a Windows issue? As you know I use some tweaks from www.winguides.com but I haven't found any that cover the disabling of this command. Am I missing something? :oops:
P
-- Steve Gibson
You can use the PWB URL filter to filter out the C: drive.
You can also use the Only Access HTTP setting in the security section of the INI file.
User avatar
OMG,
I'm such a knothead. I didn't even realize. Thanks Scott. I also noticed that an Access Message comes up, I assume to chastise anyone trying to access the drive.
You don't want to know what message I have in my file
MUAHHAHAHHAHHA!!
Philip
P.S. What if someone needs to access an FTP site? This can't be done using the Access HTTP only command, do I need to use the URL filter? Sorry, I'm such a n00b today. :oops: :cry: :cry:
-- Steve Gibson
If you want to allow anything other then HTTP sites, then only access HTTP is not for you. You should use the URL filters instead.
